Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-26-2008, 04:29 PM
Q Ball Q Ball is offline
99 Bonneville transmission compatibility
I'm in El Paso, my transmission is shot, the filter is full of metal shavings, gears are slipping, the torque converter clutch is sticking, so it shudders when I stop, etc. Definitely need a new tranny. But I can't seem to find one for my year anywhere in the area. Is there one from another car I could use?
99 bonneville, 3.8, non-ssei, 8th number in Vin is a K
Old 01-29-2008, 09:50 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 99 Bonneville transmission compatibility
Nothing special here. You have the same 4T65E and Series II “VIN K” drive train used in the Buick LeSabre, Park Avenue and Regal of the same vintage. Your local JY should have a cross-reference on this combination.
Old 01-30-2008, 12:42 AM
Thanks. For a decent sized city, theres only one junkyard, and they pretty much blew me off. And all the auto parts stores I tried would have to order it, and were charging much more than I wanted to pay. I now it won't be exactly cheap, but I know a rip-off when I see it.
Old 01-30-2008, 07:45 PM
HotZ28's Avatar
AF Moderator Elite
Try the links below and see what they have. Remember, GM offers a 3yr/100,000 mile warranty on rebuilt transmissions! This is the best deal!
GM Parts Direct - Main
GM parts 4 less
Car-Part.com--Used Auto Parts Market
Old 01-30-2008, 08:10 PM
wafrederick wafrederick is offline
Banned
Jasper is better than GM but more money,3 year ,100,000 mile warranty.Jasper put updates in and GM does not.Jasper basically finds the faults,fixes them with upgrades and they have a nationwide warranty which you can take to any Jasper dealer.
Old 01-31-2008, 06:27 PM
HotZ28's Avatar
AF Moderator Elite
Wink Re: 99 Bonneville transmission compatibility
Notice; EDIT to my above post, my mistake! The warranty for passenger cars rebuilt engines/transmissions has been extended to 3yr 100,000 miles from GM and is honored at any GM dealer nationwide. In addition, if you have the dealer install the transmission, labor R&R is covered. This is even a better "best deal"! Click Here for details.
Old 01-31-2008, 06:44 PM
Banned
I would trust a Jasper over a GM reman.Jasper has a reasearch and development area.They find the weak points which GM would not do and put in upgraded parts that last longer and stronger what factory did not put in.Same with their engines,Jasper finds the weak points and puts in upgraded parts.The Jasper would last longer and never one seen one fail yet.Here is their website: www.jasperengines.com
Old 01-31-2008, 08:02 PM
HotZ28's Avatar
AF Moderator Elite
Are you saying GM does not use updated parts? Never heard that one before, in fact, I know very well that they do! GM also has it's own R&D and Engineering team in the rebuild facilities and they do recommend part upgrades as needed and required, otherwise they could not offer a higher mileage warranty on rebuilt engines/transmissions than they do on the new car drive-train! Trust me, I have a friend who recently retired from GM after 33 years of service, rebuilding automatic transmissions for GM. He can literally tell you every upgrade GM has made to the 4T65E during the past 10 years! (Not 1 or 2-- but many)
Everyone is entitled to his or her opinion and that is what makes this site unique! In addition, we do not sell parts in the forums we only offer options. Thank you for your opinion!
Old 01-31-2008, 08:25 PM
Banned
I know Jasper does put in updated wiring harnesses in their reman transmissions and dyno tests them before selling them to the customer making sure they shift right and no other problems occur right after being remaned.Jasper is the top of the line reman companies out their and put in high quality parts.I am sold on Jasper and my father only recomends Jasper since he is a Jasper dealer even on their engines.
Old 01-31-2008, 09:20 PM
HotZ28's Avatar
AF Moderator Elite
Thanks for the additional comments on Jasper products. I am sure that they have very good products and should always be considered when shopping for engines/transmissions. Click Here for an overview of the GM transmission remanufacturing process. If you will notice, they also dyno test every transmission! In addition, I know they also replace the complete wiring harness inside the trans.
I personally have no inside, or outside interest in GM, so therefore, I have nothing to gain or loose by recommending the products!
I was beginning to think you were a salesperson for Jasper, you would make a good one; thanks for explaining the inside connection.
