Go Back   Automotive Forums Car Chat > Volkswagen > Eurovan/Multivan/Caravelle/Transporter
Old 01-26-2008, 01:16 PM
capnmike capnmike is offline
Auto-transmission hard shifting problem
I have a '93 EV with auto-trans. It was rebuilt some years ago (before I owned it). The person I bought it from thinks that it shifts hard because the trans-fluid in it is not VW-trans fluid. I'd like to know if anyone has solved a hard-shifting problem (jerking into gears up and down) by changing out the trans fluid to all VW-fluid. Please email me at [email protected] if you have any answer on this. Thanks, Mike G.
Old 11-26-2008, 06:29 PM
Plowjocky Plowjocky is offline
Re: Auto-transmission hard shifting problem
Sticky valve body. Replace it or have it cleaned thoroughly and have the system flushed completly with one of those pump things, Then replace with synthetic and consider scrapping the stock cooler in favor of a real tranny cooler that runs all hydralic instead of the coolant tranny heater favored by VW.
Old 12-15-2008, 07:55 PM
VWARRON VWARRON is offline
Vw Tech.you Have To Take It To The Dealer To Drain Fill With Vw Trans Fluid.these Transmissions Rely On The Correct Fluid And Level.if This Dise Not Repair The Problem Than The Least Expensive Thig To Do Is Replace The Trans.any And All Repairs To The Internal Components Of These Transmissions Are Tedious And Expensive.good Luck
vwarron
