Old 02-22-2003, 02:09 AM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Several questions about: CRX Si 1990
A: What type of stock motor does it have?
B: What is the stock 1/4 mile time?
C: What do you suggest to someone who has a CRX Si 1990 with failing A/C? What could you do for it?
D: How much faster would I/H/E make the 1/4 time?
E: What is the 0-60?
Old 02-22-2003, 02:33 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
alright, i have one answer for just one question, you need to find out an engine code(what engine is in there), check out my Honda Enthusiasts page, it has a bunch of engine codes, and engine stats. As for the 1/4 times and stuff, i don't know, try searching a little bit on the forum, you should find the answer, or close to it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-22-2003, 02:45 AM
...Of course you should of seen this question coming. What is an engine code and where do I find it?
Old 02-22-2003, 05:31 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
There is a spot on the front of the motor to the lfet of the exhaust maifold and under the radiator hose. It is a square with a number engraved in it. it might be covered in dirt and gunk, e depending on well the car was kept. You should see a nunber like D16A1 or something like it. this pic will give you an idea of where to look.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 02-22-2003, 10:03 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Several questions about: CRX Si 1990
D16
About high to low 17's
You can buy a recharge kit to convert to r134a, it is about 35 bux from your local parts store, very easy to do if you follow the instructions.
not much, but you may keep it in the 16's
around 9.2 secs
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
