Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-25-2008, 09:24 PM
zxseph zxseph is offline
I got hit today, need help asap!!
Uhh, I ramble, so imma break this up here.
[My story]
Ive got a 1994 Eighty Eight, and I noticed it has one small flaw that I dont really like all too much. The front turn signals are basically in the center of the car.
Anyways, I got hit by a huge SUV, and having no insurance and no experience in this situation, I just took his information down. Now I kinda wanna prevent my insurance going up, I mean, I just started driving.
He busted something, causing the brake fluid to leak like crazy. It didnt start up immediately after the crash, but when I took the car out for another drive I noticed my brakes were requiring more pressure. Then the brake light came on and I popped the hood and checked the brake fluid, and it was near empty. I had a friend give my brake fluid, and not even two seconds after I put it in and got in the car, the brake fluid light was turning on again, and the brakes were still requiring more pressure.
[My problem]
Brake fluid is leaking, I have a dent in the back door so im guessing its back there. Basically, what am I looking for? How would I go about fixing it with a low budget?
Old 01-26-2008, 12:46 AM
guitarsandcars88 guitarsandcars88 is offline
Re: I got hit today, need help asap!!
Get a buddy, have them sit in the drivers seat while you crawl under the car where the puddle is. Have said buddy push the brake pedal down and look for the leak, this might require some more brake fluid but its worth it...and its not real expensive. Find the leak, that'd be the best place to start. My guess is that a line blew, its no big deal, you'll just have to have it replaced. Its not hard to do yourself even if you dont have any experience with it. Just put it together the way you took it apart. The only difficulties you might have will be bending the lines. You dont have to get them bent the same as the original but if you can get it close its best. Just get it out of the way and not hanging down to catch on stuff...otherwise you're right back to where you started. The guys at the auto store should be able to help you with getting the right length of brake line. If you get too much, just coil the exess because its a bitch to cut. Not sure what it would cost if you took it to a shop, my guess is anywhere between 75-175 dollars...all depends on labor.
