Old 01-25-2008, 07:10 PM
needinhelp2 needinhelp2 is offline
no oil pressure
2002 Cavalier ecotech 2.2. I have no oil pressure after changing balance chain and sprocket.
Old 01-26-2008, 12:04 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: no oil pressure
Are you physically able to tell there is no oil pressure or is your sensor telling you that?
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-26-2008, 06:31 AM
Re: no oil pressure
The sensor is telling me so.
Old 01-26-2008, 08:20 AM
rhandwor rhandwor is offline
Re: no oil pressure
Disconnect the power to the coil so it won't start. Put a pressure gage in the system and make sure you don't have any pressure. If you don't have pressure I would go over your work to check everything was hooked up correctly. If you had no pressure before you started pull the pan and check for a plugged strainer. Look at the oil pressure sending unit and make sure it is plugged in first. Look at your manual and for any left over parts,that would drive the oil pump. If everything worked fine before starting it must have been something you did incorrectly.
