head ?????
SO I was looking up casting numbers for cylinder heads and I found this http://www.honda-tech.com/zerothread?id=786093
The 1990 d15b1 has the same casting number as a 1995 d15b7. Anyone have any answers to this????? Is the cam size the same?????? |
Re: head ?????
Cam has a different profile.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
Re: head ?????
so if they have a different profile why would they call it the same head??? Or is there other castings on the head to id what head it is???
Re: head ?????
If the head casting is the same..then its the same head, minus the cam. They are identical if your were to strip them down to nothing. However, the parts that used to assemble the head may be different.
Re: head ?????
Okay
Re: head ?????
80% of D-series castings are the same, lacking the D17, Vtec vs. Non-Vtec, and the DOHC heads.
The cams have nothing to do w/ the head casting numbers, they have their own part numbers. For instance, the Si cam and the D15B2 cam are different by 6* or so, yet the head castings are exactly the same. |
Re: head ?????
For instance, the Si cam and the D15B2 cam are different by 6* or so, yet the head castings are exactly the same.[/quote]
What do you mean by 6* ? |
Re: head ?????
6 degrees.
Re: head ?????
yep, sorry about that, but you'll see it alot on forums, since the actual degree sign is [ALT+0176] which doesn't work in [IMG] coding.. which is what most forums are done with.
Re: head ?????
ddd
Re: head ?????
posting random nonsense... read the rules.
