Old 01-25-2008, 01:51 PM
navajo7 navajo7 is offline
I need some help with my 98 Cavalier...
I wondered if anyone can help me..? My starter gave on me, so on the same day i got one and changed it. I got home and jacked my car up, it was like -0 degrees out, but I went ahead and finished. I then turned the key, now it won't start. I was frustrated, I'm not sure what the problem is but I think it might have to do something with the wiring or plugs. But before I changed the starter, it ran PERFECTLY! nothing wrong with it, but i also wondered if the gasline froze on me...? I used a can of starter spray to try and start it, but no-go...thats what made me wonder about the wiring, it seemed like it wasn't get'n any kick or fire! can some1 help?
Old 01-25-2008, 04:04 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: I need some help with my 98 Cavalier...
does the starter actually work or no? Get a can of drygas and add it to your tank
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-25-2008, 04:32 PM
The starter works but now it won't start. I have a half of tank of gas in it too. I put a bottle of gasline antifreeze in it too, but idk whats the problem, and yeah the starter works.
Old 01-26-2008, 12:03 AM
Lifted GMT-360!
Well if your lines are already froze. The dry gas isn't going to do anything now because the dry gas is in your tank and its your fuel lines which are frozen most likey. Try to roll it into a garage and turn the heat on. Thats really the only way you can un freeze them. Then don't run your tank that low on gas without dry gas in it.
Old 01-26-2008, 06:44 PM
Yea thanks for all your help, i found out that i missed a wire above the starter, now i connected it, my car started right up! BUT NOW it over heated on me, so i changed the thermostat, which isn't easy by the way, and now it over heats, still. How do I know if the Water Pump gave out? It leaks water, but i'm not sure if it has something to do with the Water Pump not working..?
Old 01-26-2008, 08:33 PM
Lifted GMT-360!
You probably have air in your coolant system. Take the res cap off the overflow tank and run the car till it reaches normal temp and the fan kicks on when it kicks off put the cap back on and wait till the fan kicks back on then turn the car off.
Old 01-26-2008, 08:44 PM
Yes, ok i'll try that, but a little while ago, I checked it again and I found out that there is a part, I think its called the Water Outlet, it's slitely cracked around its rim. I went online to Napa and found out that the part is under $20. That's where it's losing anti-freeze, but I let it run, the anti-freeze just leaks out in that very spot, it doesn't over heat, yet anyways. So I am certain that it's the part I need to get. Hopefully it'll be the last step to get my car back to tip-top shape!! If not it might be my Water Pump, and I found where the Water Pump is located, DAMN!! It doesn't look like it's a fun process to change it... haha
Old 01-26-2008, 09:29 PM
Lifted GMT-360!
If you get heat inside the car to the heater core then your pump is fine. Turn your heat on and see if it blows hot or not and you'll know.
Old 01-29-2008, 11:39 AM
Yea thanks, i got it running now, my water pump is good and it doesn't over heat anymore. I bought the part that was needed and it stopped leaking. Its running GOOD!! thanks for all your help!....
Old 01-29-2008, 02:19 PM
Lifted GMT-360!
no problem.
