Old 01-25-2008, 11:53 AM
zero979 zero979 is offline
90 F-150 door wont open
my 90 F-150 drivers door wont unlock or open when it is very cold outside, could it be that there is moisture inside the locking mechanism? any ideas on how i could fix this?
Old 01-30-2008, 10:59 AM
|WYG|SS |WYG|SS is offline
Re: 90 F-150 door wont open
does the key turn at all?
if so just go to local auto store and get some lock deicer and try that. if key does turn then u might have borken the lock mech.
Old 01-31-2008, 11:43 AM
no when it is really cold the key will not turn to unlock the door, but when its not very cold the lock works fine.
Old 02-04-2008, 12:16 PM
FNA FNA is offline
Sure sounds like it could be frozen, if the problem only occurs when it is very cold (I take it you mean 32 degrees F or below )
The easiest way to fix this problem is to stop locking your door in the winter. Voila.
Or you can try to displace whatever moisture is in the lock with lubricant such as a light oil.
