Old 01-25-2008, 12:59 AM
ralphysims ralphysims is offline
2000 GP GT Drivers Side Power Seat Malfunction
I have a big prob with my drivers seat. The seat will no longer move forward or backwards. It will only tilt back and forth.
I dropped my keys between the seat and the center console and needed to move the seat all the way back in order to reach them. I had a few bottles and empty pop cans under the seat when I moved.
Once i tried moving it back into place the seat would not budge. It would only tilt forward or backward. I felt underneath to see if the cans or bottles might have pulled a connector lose, but everything seems to be connected.
Any ideas as to what the problem is? Do I need a new motor for the seat? If so how hard would it be to do it yourself? Any suggestions would great!
Thanks
Old 01-26-2008, 09:05 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 GP GT Drivers Side Power Seat Malfunction
Welcome to AF.
Maybe the junk under the seat damaged the wiring harness to the forward/back adjuster motor. So a closer visual inspection may be required. You can check the voltage to the motor at the electrical connector while pressing the respective switch.
Timeslip 08/12/06
AF Community Guidelines
