Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 01-24-2008, 11:13 PM
runner4w runner4w is offline
Exclamation blowing hot when driving, cold at idle? anyone?
my 88 4runner (22re) blows hot air out the heater only when truck is at 2200 rpm and beyond. below that it blows cold air mostly, 92% of time. Replaced thermostat, not sure whats up, anyone help?
Old 01-28-2008, 09:55 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: blowing hot when driving, cold at idle? anyone?
Sounds like there is a vacuum leak, typically in the diaphragm that controls your blender door. You'll probably have to trace the vacuum tubing that goes from the temperature and mode controls on your dash to the diaphragm's location. A hand-operated vacuum pump helps this diagnosis alot by selecting a nozzle that you can push into each hole in the connector and draw a vacuum. Good vacuum lines will maintain vacuum after stopping pumping.
Of course, if you have electrical mode control and a cable-operated temp control valve (located in the heater hose tubing near the firewall), I might suggest a partially blocked heater core or hose.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
