Originally Posted by Braomi
my 98 suburban would not start this morning and hard starting for thelast 4 days in the cold morning . I left it for about 4 hours and tried again and it fired up but ran at 5000 rpms i shut it off and disconected the cruise cable and then tried again it started fine and ran normal but as i step on the gas it loses power , i called a mechanic and he suggested the throttle positioning sensor does this sound right before i go spend money on a new one.... thanks
find a mechanic that will measure the resistance of TPS when the throttle is varied if it jumps TPS is defective if it smoothly changes resistance from idle to wot you must look at other areas. TPS is good. also i find it hard to believe that with the throttle body plates closed engine could get to 5,000rpm. was gas pedal in wot mode because of floor matt? loosing power when looking to accelerate is a lean condition. possible TBS but could be fuel and many other pcm engine controls....fuel pump/pressure/relay/filter/volume of fuel pumped,this is a common area of this type of complaint......
