Old 01-24-2008, 02:43 PM
sharkmonkey sharkmonkey is offline
Exclamation Can't get the spare tire off. Help!!!
I have a 2003 T&C. What's the trick to getting the spare off?
I don't have n owners manual but I did figure out how to find the place to lower the tire. I turn it counter clockwise but the tire doesn't drop. The cable lowers but the tire hangs there.
What am I missing?
Mark "Sharky" Stover
73 Century Regal 455
05 Chrysler T&C
07 Dodge Ram SLT
11 GMC Yukon Denali XL
Old 01-24-2008, 07:56 PM
Mrbizness1 Mrbizness1 is offline
Re: Can't get the spare tire off. Help!!!
What am I missing?
You need to use a pry bar pressure on the spare tire while you are turning the bolt. The spare tire area gets loaded with dirt over time. I had to make a hook from a wire coat hanger to get the cable to release from under the car.
Old 01-25-2008, 05:45 AM
webbch webbch is offline
There's also a latch that's supposed to release when you start lowering the tire that allows it to drop down. Unfortunately, it wasn't particularly well designed and doesn't work most of the time. I loosen the cable a bit, then give the tire about 10 solid kicks at about a 45° angle and it usually drops down.
2003 Honda Odyssey EXL (3.5L)
2002 Volvo V70 X/C
1990 Chevy Silverado K2500 (5.7L TBI)
Old 01-25-2008, 07:41 AM
Thanks I figured it out. I appreciate your input though.
It was the latch that didn't release. I loosened the cable a bit then pushed up on the latch. That is a very poor design.
05 Chrysler T&C
07 Dodge Ram SLT
