Old 01-24-2008, 01:53 PM
D Ward D Ward is offline
Thermal actuator
Hi, New to the board looking for help. It seem's that im not geting power to thermal actuator in my 89 chev is there any one out there that can help. I just replaced the actuator last year.... Thank's for your time..
Old 01-24-2008, 03:57 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Thermal actuator
What does this "thermal actuator" control?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-24-2008, 04:12 PM
Its for the 4X4 that engages my front axle.
Old 01-24-2008, 04:13 PM
Old 01-24-2008, 04:23 PM
J-Ri's Avatar
Did you check for power to it, or assume that new means good?
Check fuses if you havn't already. If good, check for power to the switch, and then out of the switch if it has it going in.
There is a kit (I forget who makes it) that has a cable that runs down and takes the place of the actuator. A lot of offroaders upgrade to that because of the problems with the original actuator going bad. I don't think it was very much, and it may be easier than finding and fixing the problem. It's really just a preference thing.
Old 01-24-2008, 04:55 PM
The fuse is ok thats the first thing i checked the actuator is good. Sorry i mite sound dumb but where is the switch. I have always had jeep's so this is some what new to me i have been learning as i go.
Old 01-24-2008, 05:32 PM
J-Ri's Avatar
You don't sound dumb, you can't learn if you don't ask!
The switch is in the lever you pull to put it in 4x4, infact, the lever is only a switch, there is no mechanical linkage.
Old 01-24-2008, 05:39 PM
Thank's i'll check that later. I wasn't sure if there was a switch there or not. So the only mechanical is the shifter rod that engages the transfer case. I'll let you know what happen's thank's again for all your help.
