HI Everyone,
I have recently purchased a 1990 camry, 4cyl, 117k miles, 3s-fe motor, 2.0, auto trans. from reading this form I have narrowed my problem to the speed sensor mounted on the trans. however I need conformation before I go and buy the $$$$ 224.00 $$$ part from autozone.The symptoms are: -speedometer and odometer not working -RPM, temp. and fuel gagues work fine -when driving: car seems to start moving in second gear Does not shift at any speed RPMs shoot as high as 4-6000 moving 35-45mph feels like the trans is locked in second gear No response when shifted in to D2, L, or od/off mode cannot engage cruise control while driving Chugs gas like nothing -Trans. fluid is bright red and apears fresh -no Check Engine light -cv half shaft sounds broked on passanger side, dont know how long its been broken. I originally thought that the tranny is bad and I'm out a few grand to fix it but now Im hoping that the speed sensor may solve the problem because the car drives fine aside from the shifting! Any help I can get will be greatly appreciated!!! also if the problem is the sensor can you also tell me how to get to it. I dont see it. Do I need to go through the wheel well or am I not looking hard enough, the chiltons manual I have does not help with the speed sonsor at all! |
Re: 1990 camry symptoms
If there is a fault with your VSS, your "Check Engine" light won't come on, but it will record a trouble code 42 in the ECU. Check your Chilton's or Haynes manual on how to retrieve those codes through your diagnostic connection port under the hood to verify.
I don't know where the VSS is located...if I find out I'll repost.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Why did you buy it?
Camry for $800, I fell for it.
Dude told me everything is fine, he's getting rid of it cause its his second car and he needs money for school. I Trusted him. I have trust issues...I know... Idiot MEEEEEE!!!!!!!!!! Thanks for you help though, I'll take it to autozone for a scan today, and see if I can retrive any codes. I'll post update asap. Thanks again! |
Your car uses the old OBDI fault detect system. Autozone can only read OBDII & III codes. You can read your codes yourself in your driveway. Open the FAQs thread at the top of the forum. Scroll to post #33 (little yellow number in upper right of every post). The first link in the post gives you the procedure. It involves jumpering two contacts together on the test plug and counting the check engine light flashes. You'll read of an SST tool. That's Toyota lingo for a paperclip.
Or...: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
The VSS is located on the rear part of the differential housing. There is an electrical connector and a hold-down screw attaching it to the housing. You might be able to get to it by removing the air intake hose and resonator.
