| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
90 3.1 Lumina dies then starts when cool
My Lumina died on my way home last night. It acted like I just turned the key off. I went back about 1 hour later, and it started for a moment, ran very rough, and then died. Cranked again, but no start. I went back after another hour and it started and ran just fine. I am thinking something got warm, and quit, and then after cooling off it worked just fine. I know this same thing happened to the previous owner a couple of times. Any ideas on what to check, or replace? I have done a search, and some problems are similar, but after 2 hours mine starts and runs fine. Any help would be appreciated!!
#2 | ||
Re: 90 3.1 Lumina dies then starts when cool
#3 | |
Lactose the Intolerant
![]() Join Date: Aug 2004
Real typical of ICM or crank position sensor going out too...both like to fail when heat-soaked, then work once cooled down...
If you have a can of starting fluid, hit it with a shot when it stalls...if it starts on it and dies again, investigate fuel delivery, if not, it's probably one of the aforementioned.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
#4 | ||
Thanks for all the great help!! |
#5 | |
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
http://www.autozone.com/az/cds/en_us...rInfoPages.htm Here's info on both...if yours has the CKP sensor mounted around the crank pulley rather than in the middle of the block, make sure the wiring is not sagging and rubbing the crank pulley...will cause weird stalling and no-starts also... It says you have to idle relearn after replacement with a scan tool...you don't actually, but it will hunt up and down for proper idle speed and may even die at idle a couple of times until it's driven for a while...the idle will relearn as you drive it...or you can block the wheels and let it sit and idle in gear with the e-brake on for about 15 minutes and they usually settle down and relearn too..
#6 | |
I have not hooked up a scan tool yet because the SES light is not on. Will this car have codes if the SES light is not on? Another symptom is when I turn the key on the tach jumps, but then when it starts the tach goes as far as it will go and stays there. Way above 8000 rpm mark, and the speedometer is about 20 mph off at highway speeds. Are these a symptom of another problem, or maybe part of the same problem? Thanks again for all of the great info, and help!! My Dad gave me this old car, and I really like driving it, I just have to work out the bugs.
#7 | ||
There could be soft codes set that don't make the light stay on.
#8 | |
I replaced my crank position sensor, and drove the car for awhile. It died on me as I was pulling in my driveway. At least it did not leave me stranded again.
While I was trying to troubleshoot, I noticed when I would turn the key to the on position the fuel pump did not sound quite right. I dropped the tank, and installed a new fuel pump, and hoses. So far so good!! I have driven about 100 miles since then and no problems. Thanks to everyone for the great advice!! |
