Old 01-24-2008, 02:19 AM
Gazer Gazer is offline
98 T&C Transmission Code advice
We were driving our T&C on the free way. Tapped the brakes to see if the roads were ice and the engine reved up. It was as if the engine was not connected to the transmission. Long story short it went into limp home mode. OBD codes are as follows:
P1765 Switched Battery Failure
P1732 UD Pressure Switch Circuit
P1727 4C Hydraulic Pressure Switch CKT
LR Clutch 51
OD Clutch 89
24 Clutch 53
UD Clutch 59
Any suggestions? Can you tell me what these mean? Any help greatly appreciated!
Old 01-24-2008, 03:43 PM
dcx96 dcx96 is offline
Re: 98 T&C Transmission Code advice
LR Clutch 51
OD Clutch 89
24 Clutch 53
UD Clutch 59
okay the 1765 code means. an open or shorted condition is detected in the trans relay control circut, this relay supplies power to the TCC. no codes in my book for the others sorry
Old 01-25-2008, 11:38 PM
I have tried different relays, but didn't change anything. If the weather warms up I may start to try to go through the wiring. Thanks for your thoughts!
Old 01-29-2008, 07:05 PM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
P1765- ChryslerTransmission 12 volt supply relay control circuitP1732- ChryslerUD Pressure Switch CheckP1727- Chrysler4C Hydraulic Pressure Switch Circuit
I have tried to find definitions for these, mainly 1732 and 1727 but no luck, will probably call dealer tomorrow and ask. I am wondering if 1765 may have set 1732, and 1727, off being it is a 12 volt circuit error.
Old 02-07-2008, 01:38 AM
I checked the continuity between the wiring harness plug at the transmission and the plug at the TCM. Every thing checked out ok. It has 196000 miles on it. So I am ready to give up on it. My wife loves this van and is begging me to go ahead and put a transmission and a engine in it. Oh the things we do for love. Maybe when spring comes I will tackle it.
