Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-23-2008, 10:51 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
Routing of speed sensor cable
Brian;
My server for pictures is still down. I'll e-mail you the photos of the cable routing tomorrow.
In the mean time you'll have to settle for a written explaination. The cable is routed from the sensor (located on the left rear wheel) along the brake line that runs under the driver door. It is tie wrapped to the brake in several places along the run forward. I followed the cable up along the brake line to a connector that is tie-wrapped to the upper frame member. The cable exits the connector and enters the wire harness that goes to the fire wall.
Hope this helps.
Jerry
1999 Panoz GT-RA
Old 01-23-2008, 11:29 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Routing of speed sensor cable
Thanks, that helps a bunch.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
