Old 01-23-2008, 09:59 PM
ctchevy427's Avatar
ctchevy427 ctchevy427 is offline
4 WD Dash Light
Does a 2006 Silverado HD with with the electronic shift four wheel drive have an indicator within the cluster that comes on when you hit the 4WD button or is there only a light on the floor shift models?
Old 01-24-2008, 05:01 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 4 WD Dash Light
I believe there is a light, both for 4x4 and 4x4 low. All lights should come on for the bulb test (first ~2 seconds when key is "on" but not "start").
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-25-2008, 01:25 AM
16th hippy 16th hippy is offline
Re: 4 WD Dash Light
if you can get ahold of a tech2 scan tool you can turn the light on. my '98 s-10 is 2WD, but usnig the tech2 i can make the 4WD light come on in the cluster...lol.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
