oil change
2002 windstar SE V6,have been useing mobil 1 in the engine now for couple of years is it safe to go back to standed oil
thanks frank |
Re: oil change
Yes, it is safe to go back to "normal" oil.
You will want to use the recommended viscosity, 5W-20.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
Re: oil change
Any reason why you want to go back to dino?
*Twin Cities MN* |
Re: oil change
I do that from time to time. I switch with mobil 5w-30 synthetic to 5w 30 mobil 5000. From time to time. If I can't fine the synthetic on sale. I don't like to use 5w-20. I just think thats way to thin of an oil. Also I heard the only reason Ford recommends it is because of fuel millage rating. But I also don't use a thicker oil.only 5w-30.
Re: oil change
I don't mean to change this post into a viscosity debate, but until I see some proof that 5w20 is "too thin" and detrimental to an engine, I don't see why you wouldn't want to use it in a vehicle that specs it. Any used oil analysis I've seen on 5w20, even when used in engines that spec'd 5w30 showed nothing but stellar results. Why would you not want to maximize your fuel economy? On top of that, 5w20 is a synthetic blend that can be had for under $2/qt. It's more than you'll ever need for a Windstar.
Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Re: oil change
On the BITOG board (Bob Is The Oil Guy) the 5w/20's have good analysis results. I use Pennzoil Platinum 5w/30 since I've found really good deals at O'Reillys (6 qts for $4.00 after rebate) and Checker auto (6 qts for $1.79 after rebate). Gotta shop around!
*Twin Cities MN* |
Re: oil change
Re: oil change
i cant remove the oil plug in the pan ,the bolt is rounding off, i have a new bolt but since its to cold to fix it and i might have to remove the oil pan,ill wait till its gets warmer to fix it ,i order a oil changer pump to remove the oil from dip stick,i wanted to change the oil and again in a couple of days to get as much of old oil as i can ,till i get the plug fixits been likt that since oct.
i thiught it was a waste of money to replace it with mobil 1 since its only going to be in a\couple of days. thanks frank |
Re: oil change
Just make sure you get the right size set. Vise grips sometimes will make it worse.. Also if you do try that oil pump thing it may be better to remove the dip stick tube. |
Re: oil change
that was the first thing i tried was sears bolt extractor,i bought the set and it wouldn't move, i was afraid to break the bolt or the oil pan, i have to be prepare to remove oil pan,at worst condition
Re: oil change
Did you use a drill and internal extractor? The external extractor I would hope would work. If all else fails, put some propane heat on just the plug. Then quick qwench just the plug with a wet rag. Try it, and repeat if necessary. I doubt you will hurt the oil pan just torquing on the plug.
Re: oil change
that was going to be my next try but its just to cold outside will try it as soon its get warm
