Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 01-23-2008, 05:17 PM
HRthirty1 HRthirty1 is offline
problems boosting
hello all ,
i have nearly got this rb25 det working properley in my hr31 however when i am driving it gets to about 4500 rpm then tries to boost but nothing happens. the engine does not go faster,does not gain rpm and sounds as if all the boost is just being dumped through the wastegate or blow off valve.
i have been told that this is due to the MAP sensor not functioning and i dont even think i have 1 wired into the ECU. i have purchased a MAP sensor but dont know how to install it can anyone help me with info or diagrams?
i would really love to get some enjoyment from my car finally.
Old 01-25-2008, 11:13 PM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: problems boosting
If your car has a stock computer in it, there is no MAP sensor that can be fitted. Whoever told you that should bury their heads BACK in the sand.
Three possible problems:
1. You have a boost leak between the turbo and the throttlebody. The air being leaked causes the motor to run really rich and lose power/no want to rev. This is the most likely culprit.
2. Your spark plugs and fuel filter are likely to need changing(if not already) and I would also recommend changing the timing belt if you have not done so already.
3. Check that the rubber intake pipe between the airflow meter and the turbo is not sucking itself closed when hot, as the massive vacuum causes the pipe to close shut and reduce air flow.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 01-29-2008, 01:33 AM
Originally Posted by HRthirty1
hello all ,
cheers mmcleo11 , your advise was right on the money.
there was 2 spots where the air was geting to the turbo after the sensor these have been blocked now.
there was also a little gold pipe ontop of the motor which has now been blocked ,is this for the boost guage hose?
A mate of mine also blocked the hoses running to the blow off as it wasnt working properly.
my car is now running very well and im very happy this little sleeper skyline has some real potential ,thank again
Old 03-20-2008, 11:41 PM
mmcleo11's Avatar
The gold pipe should connect to your brake booster.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
