Old 01-23-2008, 02:45 PM
whitedavidp whitedavidp is offline
1995 S-10 Gets Code 13 - What To Do?
My 1995 4 cylinder S-10 has its service light come on. Following my manual I have read the trouble code(s) and find only 13. The book says this means O2 Sensor Open Circuit. Does this mean that the sensor needs to be replaced? Thanks!
Old 01-23-2008, 04:25 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 S-10 Gets Code 13 - What To Do?
4.3 engine?
Code 13 is open sensor circuit.
Wiring or bad sensor or heater circuit if the heated sensor.
Also check fuse if it has one.
MT
MT
Old 01-23-2008, 04:41 PM
Originally Posted by MT-2500
4.3 engine?
MT
Hi and thanks. It is a 4 cylinder and I believe this makes it a 2.2L engine. The O2 sensor has a single wire so I do no think it can be a heated model. When you speak of a fuse, would this be in the fuse block on in-line?
Cheers!
Old 01-23-2008, 04:58 PM
MT-2500's Avatar
AF - Advisor
Single wire 02 sensor has no heater or fuse.
You can check voltage output with a good volt meter or I would just replace it.
MT
