Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 01-23-2008, 01:27 PM
Mauinix Mauinix is offline
Doesn't Anyone Answer These???
I am beginning to have multiple electrical issues. I believe my heater core has quite working, but the relay continues to cycle constantly, inside the dashboard area, and I have no heat at all. It's very annoying to say the least. Anyway, I've also been receiving noise shorts over my radio, until the point that I have to shut it off, completely! My CD player cannot be heard at all, but appears to be working. Does anyone know if there is a common denominator or can you just reply with any help with any of the above issues??? I would appreciate it...
Old 04-10-2008, 03:28 PM
smplyred smplyred is offline
Re: Doesn't Anyone Answer These???
I was having an issue like that with the CD player that was already installed when I got the car. The CD player portion didn't work. Once I installed a brand new CD player...I haven't had the problem since.
I love my car but I hate my car! ~smplyred
Old 04-16-2008, 03:04 PM
Towncar's Avatar
Towncar Towncar is offline
I have no idea why I haven't see this post sooner.. I don't have a Mark but I normally browse all the Lincoln forums.. sorry.
Yes, these are multiple issues, not related.
The Heater problem:
The way you describe this one, it sounds like the Blend Door Actuator has broken. This is a common issue. Parts are relatively cheap compared to the labor. On my Town Car the whole dash panel needs to be moved a bit in order to get at the BDA. I can look up the process for your's if you like. Some folks found a way to manipulate the Door manually and left it at that.
The Radio problem:
This one needs further diagnosis. If you have HU removal tools you should pull the HU out, then re-seat it once or twice to make sure the connectors are contacting correctly; however, the 'pop' you hear is most likely a high voltage discharge.. not necessarily related to the stereo system. You might have a coil leaking voltage, or possibly a shorting Spark Plug Wire.
Also, after you prove the Ignition system isn't at fault, your Amp might be the next thing to consider, then finally.. your speakers might be shot.
-Steven
1996 Town Car, Cartier
Old 04-22-2008, 10:18 AM
Goddard007 Goddard007 is offline
your coolant level affects heating as well. Atleast it did on my 97 lsc.
