Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-23-2008, 12:24 PM
luisgsxr_07 luisgsxr_07 is offline
Question air intake manifold leaking
I have a 98 cvpi with an all plastic manifold that has a crack in the front leaking coolant. I did the research and found this is a common problem with the all plastic manifolds. I have purchased the new manifold with the aluminum cross over in the front. Now here are my questions. What should I replace while I'm in there. What should I be carefull not to do. And I also have a misfire in cyl 6 does any one know the cyl order on my model. I'm pretty sure it is a bad coil. So I will replace it while I have it out. Please help. Thanx in advance.
Old 01-23-2008, 06:30 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: air intake manifold leaking
Look closely at the heater hose under the intake that comes off the back of the water pump. If you have the intake off, I might invest in a new one. The cylinders are numbered from front to back, 5 is drivers side and 1 is passenger side.
5------1
6------2
7------3
8------4
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-23-2008, 07:04 PM
Thanx for the help. If the computer is giving me the engine code for a missfire in cyl 6 is there any thing else I should check before I change the coil.
Old 01-24-2008, 06:42 AM
way2old's Avatar
TOKEN HILLBILLY
Most of the time it is either plug or coil or thr boot may be arcing through to the head. I have omly had 1 injector cause an engine miss on all the CV's we have serviced. Good luck
Old 01-24-2008, 09:24 AM
Is there anything I should be extra carefull with. Like any parts that are known for easy breaking. I gotta make sure this job goes as smooth and cheap as possible. Thanx again.
Old 01-24-2008, 06:55 PM
way2old's Avatar
TOKEN HILLBILLY
The only thing we have a lot of problems with are the injector and coil connectors breaking. Also, check with your Ford dealer. It is possible you can get it fixed for free. If you don't mind sending me your VIN, I can run it through Ford and see if your intake is under warranty. May be a free repair for you.
Old 01-26-2008, 04:06 PM
My vin is 2fafp71wxwx125847 yeah if you can check that out for me I would be greatfull. Also I swapped out that coil worked like a charm.
