Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-23-2008, 12:08 PM
4g63rice 4g63rice is offline
Thermostat
I read that a thermostat for a 1991 talon tsi should be opening at 190 F. If i get a thermostat that opens at 180 F will it still fit?
Does the size matter depending on the opening temp. of the thermostat?
Old 01-23-2008, 12:55 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Thermostat
The opening temp of the thermostat has nothing to do if it will fit or not. A 180F thermostat will work in your car but it has to be made to fit your car.
This is just like any other part for a car. They are made specific for each vehicle
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-23-2008, 01:00 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: Thermostat
Yup. Also if you live in a place where there is no freezing weather you can yank the thermostat out and run freely. This is only ideal for warmer climates as with cooler climates where a heater may be required , it will keep the OT so low your heater will only blow cold air.
Also if you look around on the net you can get direct fit thermo's with varying opening / closing temps.
2004 Mazda 6i
1997 Tahoe
Old 01-23-2008, 01:51 PM
Holset powered 420a
Re: Thermostat
This is a very BAD idea. Do not run your car with out a thermostat. The engine is design to run at a certain temp range and when you change that to much it will make your car run bad. Your car runs richer when the motor is colder so taking out the thermostat could make you run rich for a longer period of time trying to warm the motor up.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-23-2008, 03:32 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Thermostat
I have also heard that if the engine has been running for a long time considerably under the temperature it was designed to run at, moisture can begin to collect inside the engine. When the engine heats up that water is evaporated. I know last summer during out heat wave in SC I took my thermostat out just for the hell of it to see if I'd run any cooler. The data logger proved that to be wrong. I ran at exactly the same temp on the interstate with or without a thermostat.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 01-23-2008, 08:29 PM
MazdaX's Avatar
Re: Thermostat
I run all my cars in summer without thermos and with during winter. I ran my eclipse for about 2 months this winter without the thermo and I didnt notice any difference in warm up times. The only thing I noticed changing was how cool the engine runs when flying on the freeway =)
Lots of people will argue the matter that a thermo is good and lots will argue a thermo is bad but I stand neutral on the matter. It serves its purpose when needed and is pointless in 110 degree weather.
2004 Mazda 6i
1997 Tahoe
Old 01-23-2008, 11:24 PM
Holset powered 420a
Re: Thermostat
If you want to run cooler than put a lower thermostat in the car.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-25-2008, 09:18 AM
Re: Thermostat
Will my car run better if i run cooler?
Old 01-25-2008, 11:26 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Thermostat
Depends on how much cooler. If it's too cold, you run richer which is not good. Normal temp is what ~200f? It's good to run no less than ~190f or so.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-25-2008, 01:07 PM
Holset powered 420a
Re: Thermostat
Your car will run better if its colder only to a certain extent. Like Dave said if its to cold its going to hurt performance.
Your main concern with the cooling system should be how well will it keep the motor cool on hot days and during hard driving. You cant expect to gain a whole lot of HP by running the motor cooler, but having a motor that gets hot after a few passes at the track will hurt performance a lot.
Your intake temps and intercooling will also loose you some HP if you start to heatsoak it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-25-2008, 01:22 PM
david-b's Avatar
Dave is THAT guy
Re: Thermostat
That's why it's better to run with more flow into the engine bay. That way the actual motor is at the proper operating temp, but when you are driving or making passes, the air blowing in cools down all the bay, piping, and everything else in general. My temps dropped some after I striped out the A/C and basically made the front grill only have a high flow radiator. I hope on the expressway and watch my temps drop ~5-10 degrees (wind is a factor) on average. Then, make sure your header or exhaust or whatever is wrapped in header wrap and that keeps the bay cool too.
75 Monte Carlo
Old 01-26-2008, 11:11 AM
Re: Thermostat
how about me running a 180F on my 91 tsi?
Although it's suppose to be 190F.
Old 01-27-2008, 11:17 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Thermostat
I personally don't like the idea of running without a thermostat.
The 180 tstat mod is a very common one, you won't have any issues with it. And there are direct replacements in that temp rating, though I forget which vehicle it's from...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-28-2008, 03:15 PM
george536's Avatar
george536 george536 is offline
Re: Thermostat
KEEP THERMOSTAT PERIOD
Also because if the vehicle never reaches the temperature that vehicle will not go closed loop. when its in closed loop means the pcm starts to adjust a/f by the o2 sensor. if it never reaches operating temp it will stay open loop and just go off by fuel maps it has stored, just like when you go WOT. goes into open loop. so its bad.
and as for obd2 vehicles when tested for state inspection (SMOG) the vehicle never runs its monitors because of never reachin operatin temp and will fail obd readings for state testing in some states.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
