Old 01-23-2008, 09:38 AM
nbubak nbubak is offline
Exclamation 98 Grand Prix GT keyless entry problem???
my keyless entry wont work at all have changed batteries numerous times and still nothing......i have tried to reprogram the remote with the car but that doesnt seem to work either.......can anybody help me with this problem or should i just buy a new keyless entry system and install it?????? thanx
Old 01-23-2008, 10:03 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 98 Grand Prix GT keyless entry problem???
was this the same remote that came with the car, or did you purchase it from somewhere else?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-23-2008, 10:45 AM
its the remote that came with the car
Old 01-23-2008, 10:53 AM
tblake's Avatar
In God We Trust
interesting.
I guess maybe make sure that all the fuses are good for the rke systems and also make sure your following the reprogramming procedure exactly.
Then maybe I'd get a different remote with the same serial numbers on the back of the one you have and attempt to program it. Got a different vehicle that has the same remotes?
Old 01-23-2008, 11:27 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Did you make sure the battery is installed properly, and not upside down? How are you trying to reprogram it? Are you doing the resync proceedure (holding down the lock and unlock buttons for 10 secs) or are you actually putting the BCM in programming mode by removing the Mall-PGM fuse and following the proceedure in the owners manual?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-23-2008, 07:08 PM
i tried the resync programming i havent tried the other reprogramming im not sure how thats done??
Old 01-24-2008, 04:33 PM
m0ng00se m0ng00se is offline
You can reprogram it like this.
1. Remove the key from the ignition.
2. Close all of the doors.
3. Remove the “ MALL PGM” fuse from the fuse panel. Use the legend on the fuse panel or owner’s manual to properly locate the “ MALL PGM” fuse.
4. Insert the keys into the ignition, and turn to the ACC position.
5. Turn the key to OFF and then back to ACC within 1 second.
6. Open and close any vehicle door. A chime will be heard when the system enters the programming mode.
7. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds. IMPORTANT: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
8. Repeat the previous step on each additional transmitter to be programmed (including any existing remotes).
9. Remove the key from the ignition.
10. Install the “MALL PGM” fuse.
I went through this procedure with my 98 GT with an aftermarket remote and it worked like a charm. Just be sure to follow the instructions word by word, or else it wont work.
Old 01-25-2008, 05:39 PM
i tried reprogramming with the direction used above but still nothing i after 7 seconds i heard no chime???
Old 01-25-2008, 07:08 PM
You should hear your car making a bunch of annoying beeps if you do it right. Just be sure you do EVERYTHING word by word. If it just doesnt work, you could have a malfunction with your keyless reciever/remote.
Old 01-25-2008, 07:35 PM
still not a thing? should i try buying a new transmitter?
