2000 Blazer external washer tube fitting.
Greetings,
I'm currently in the process of replacing my rear wiper motor. While trying to remove the washer fluid tubing from the external fitting on the liftgate, the barbs broke off of the fittng (inside of the tube) ; now I have no way of reconnecting the tubing to the rest of the system when I put everything back in place.I was wondering where/if I could find a replacement fitting. Something tells me that it's not a common part that gets replaced, and that it might be difficult to find. Thanks for any help/solution that is provided! |
Re: 2000 Blazer external washer tube fitting.
If it is a special fitting the dealer is your best bet.
Also most parts places have normal vacuum hose or washer hose and fitting parts kits that you may be able to splice it together. Good Luck MT.
