Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 01-23-2008, 12:16 AM
colten114 colten114 is offline
Question Please help!!!
I was wondering if a 1992 Sentra Xe transmission a motor can be swapped into a 1994 Sentra Le with the same motor mounts and tranny mounts? Thanks alot
Old 01-23-2008, 03:37 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: Please help!!!
i believe it might work as long as both cars use the 1.6l
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 01-23-2008, 08:59 AM
vgames33 vgames33 is offline
Re: Please help!!!
The only problem should be the speed sensor. The 92 will have a mechanical sensor, and the 94 will have electric. I'm not sure if you can just swap them.
Old 01-23-2008, 04:44 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Please help!!!
you cant. but if you keep the dash from the car you use the transmission/engine from, you can just install the dash and it should work ok.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
