3000GT VR4 Tranny
I'm new to this, so if if I'm not doing this right, sorry.
I have a '91 VR4 GETRAG tranny without a 4th gear. No unusual noises, just nothing when I go to 4th. I thought I could tear it down and check it out, but I can't get the thing apart!! I have every bolt that I can see removed, but the cover only moves about 1/2" before it stops. I'm getting desperate; the crowbar/sledgehammer is looking better all the time. Has anyone torn one of these down? What's the trick? |
Re: 3000GT VR4 Tranny
havent really opened mine up, but u could try that. if you mess anything up, i have one that i could sell you. shifts good, just needs one sycro.
'93 3000gt VR-4
170k, 27k on JDM motor MBC @ 14.5 psi Datalogger Intake T-Pros Downpipe Gutted Pre Cats Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs Audio Sony Deck Eclipse 6x8 2 ways in the back Clarion Kevlar cone Component System in the front 2 Alpine Type S 10 inch DVc Subs 1 Audiobahn 10 inch DVC D Jones Series One 800 Watt Jensen amp and a soundstream 300 watt 4 ch to the speakers And still under 4000 lbs w/ me in the car ![]() |
Are you just talking about the end cover that covers the 5th gear? (located on the passenger side of the tranny). If so then there is a little nub that holds it on even after you undo all the bolts, mostly you need to tap it with a hammer and then wiggle the end off. Be carefull not to lose the spring located just inside it.
1992 Mitsu 3000gt sl 5sp - High flow filter - Pioneer head, dual 10's - H4 headlight conversion - Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod - LED "Snake Eyes" - Lightweight Crank Pulley -More to come- ![]() Your 3000GT is the 5095th out of 6964 . Only 41exactly identical Bloody Knuckles from Changing Fuel Filter Crew Member #1 |
if your trying to take the bellhousing off there is a shifter that has to come out first. Thats really the only way I would take a tranny apart.
Coop |
if ur removing the end cover, be sure to remove the allen bolt from under the circular plastic cover.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
If you want to take the trans apart you have to start at the end case. It wont come apart the other way.
Theres a few guides for tearing one apart online. You just have tio find the guides.
I have a link to the repair manuals for 1st/2nd generation 3/S. Let me know if you are interested.
Never bring show to a go fight.
And a TT conversion brewing.. |
Coop |
Ahh, I was thinking of the NA trans.
here is the AWD transmission manual http://stealth316.com/misc/3S_AWD_tr...ice_manual.pdf. pages 33-36 show how to remove the rear cover.
The early 1g Getrags allen bolts are tiny. It was 25 splines (I beleive)that got the larger bolt.
where in vegas did you find them?
Jason |
I did a search for W5MG1 parts..came up with the site in Vegas called Drive Line Service of Las Vegas, that's the link above. They list a complete rebuild kit for the W5MG1 w/transfer case for $533.84, contains bearings, gaskets, seals,etc...however syncros are sold separately. |
