Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
View Poll Results: Do you feel this is a common occurence with the Gallant
yes 0 0%
no 0 0%
sometimes 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 01-22-2008, 08:55 PM
north cac-101 north cac-101 is offline
car will not start.
I have a 2000 Gallant. I had trouble starting the acr at times. Found a corroded pos. battery post connctor. Change post and jumped car all good. A week later car would not start. So i gat another jump and change the negative post on battery. Jumped car and it started. When i went to take off i put car in drive and it cut off. We gave another jump with no luck. Car would not start. When I tried to start car all i could here was the starter solenoid click. So I changed the starter and still the same problem. So i had both starters tested and the tested good. I had the battery tested and it was also good. I even turned the crank shaft pulley to eliminate a seized motor. Any ideas on what it could be? Need help. Thanks.
