Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-22-2008, 11:50 AM
readallen readallen is offline
Question What should i use?
96 jimmy 4wd 4.3liter 170k -- should i use lucas oil stabilizer with 5w-30 oil, what oil and filter brand, lucas gas additive, bosch or autolite or ac delco plugs , kn air filter, what brand atf and filter, what universal joints, what should i put in differentals. so what stuff is the best for my car???????
Old 01-27-2008, 10:37 PM
thebeastjuggalo thebeastjuggalo is offline
Re: What should i use?
well thats a whole lotta question :P
fist off, u shouldnt really use any oil additives, it u think it needs flushed then run some seafoam through it before u change the oil...personnaly i would suggest a k&n oil filter simply for the fact it doesnt flow nearly as much oil back into the pan when the truck sits, so when u start it, it wont be a dry start, and as for oil, depends on what u can afford, if u can afford say some redline synthetic that would be your best bet....for a gas additive, just run a can of seafoam through it once a month or so....for plugs, any plug that is both platinum tip and platinum core will work the best...atf filter dont matter what brand u get...dont really matter for the universal joints....differentals i would say to use lucas
*traded in*1995 gmc jimmy, 4dr, 4x4, vin w
PERFORMANCE: ebay-chrome intakes air intake, magnaflow cat converter, flowmaster 40 muffler, electric fan, high beam headlight relay, accel 48,000v super coil, ADS high performance chip.
*new ride*2004 pontiac sunfire
PERFORMANCE: K&N typhoon intake, b&m shift plus, copper springs for plug boots, lightweight (3oz) alt pulley, thats all for "now"
Old 01-29-2008, 02:35 AM
16th hippy 16th hippy is offline
use delco plugs. no need to add anything to oil unless there is a problem, and for other than general cleaning, there isn't much a mechanic in bottle can do but delay the inevitable. would reccomend removing the diff covers for fluid change to inspect everything to make sure there are no chunks or anything.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
