Old 01-22-2008, 11:41 AM
Khill Khill is offline
Question questions for tune up, '04tb, 4.2L, 106K mi
not exactly sure what care the vehicle has had over the years but it is over 100k miles and I am wondering what I should do to give it a full tune up, as much as I can anyways!
Thanks in advance!
Old 01-22-2008, 12:06 PM
G.A.S. G.A.S. is offline
Re: questions for tune up, '04tb, 4.2L, 106K mi
Your full tune up will consist of.
distributor cap, rotor, plugs, wires, oil and filter, air and fuel filter.
Go with the factory recomended tune up parts or you will be doing this again next year.
Old 01-22-2008, 11:35 PM
thanks for the reply but what wires? all the wires? how do you do this without taking the entire engine apart much less the rear computer console? Obviously I havent done this before so it sounds a little daunting...
another thing, I have heard that K&N filters and such are good quality, should I use these instead of factory?
thanks
Old 01-23-2008, 03:43 AM
the wires I am refering to are the spark plug wires, They go from the distruibutar cap to the spark plugs.
As for the K&N filter, I myself would use a wix filter.
Old 01-23-2008, 09:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
thanks
I would say no to the K&N filter deals.
Do not believe all of the more mileage and more power adds.
Stay with AC Delco OEM Type stuff.
Wix is the best aftermarket filters.
On the wires it is just the plug wires that should be replaced.
On the plug wires do you have a dist or the new coil on plug setup?
Either way replace the plug wires if you still have them.
And check the latest AC delco spark book for number changes and sometime gap setting changes.
At a 100K there is other stuff that needs looked over and checked to.
Belts and hoses and coolant service transmission service and brake pads checked just to name some.
Good Luck with it.
MT
MT
MT
Old 01-23-2008, 10:29 AM
Thanks, what do i replace the wires with? where do i get new ones?
The engine has the coil setup, what does this change?
By rotor, do you mean radiator fan?
Old 01-24-2008, 07:43 AM
Jethro Jethro is offline
Send a message via AIM to Jethro
i dont know of any trailblazers with a distributer cap since 2001
2002 LT Trailblazer 4x4 One of the first of this kind on the road
2003 3500 LT Silverado 4x4 ext cab
2006 Heritage Softail HD FLSTI
Old 01-25-2008, 12:26 PM
wardak33 wardak33 is offline
trailblazers don't have wires or a distributor cap, etc. it is all direct ignition meaning that there is nothing to replace except for the spark plugs...
2002 Oldsmobile Bravada AWD w/ SmartTrak
1999 Mitsubishi Galant 2.4L I4
Old 01-25-2008, 07:15 PM
I did have 2 boots replaced on the coil wire going to the plugs due to carbon trails and arcing. This was done b/c I had intermittent missing while cruising. This fixed that problem.
Old 01-26-2008, 12:50 AM
hyperlube: good or bad?
fuel system cleaner and oil additive
thanks
Old 01-26-2008, 09:03 AM
MT-2500's Avatar
AF - Advisor
thanks
A lot of oil additives and hyper lube stuff is snake oil.
The best additive is no additive just good fresh clean oil.
Pour in tank Fuel system cleaner only helps aid in keeping the injectors clean.
If they are bad a professional clean or new injectors are the way to go.
Good Luck
MT
MT
