Old 01-22-2008, 10:18 AM
anacdoctor anacdoctor is offline
Banned
No Heat 97 Park Ave
I disconnected my battery and now the air does not get hot when the heater is on.
Old 01-22-2008, 06:50 PM
Blue Bowtie's Avatar
Registered Offender
Re: No Heat 97 Park Ave
Does the car have electronic temperature controls?
Old 01-22-2008, 09:55 PM
Banned
Yes it does have electronic controls
Old 02-14-2008, 07:54 PM
anthonyj26 anthonyj26 is offline
Red face Re: No Heat 97 Park Ave
I have the same problem with my 95 PA ultra, no heat electronic climate control starts blowing before engine is warm and is blowing cold air. After the engine warms still no hot air. Just replaced water pump, still blowing before heats up and blowing no heat at all times. Fan used to start after the engine warmed up, now they blow cold air as soon as I turn it on. Any suggestions?
Old 02-14-2008, 08:12 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Do you have a flashing light on you ACC control when you turn the key on? If so, you have a fault in the system. It could just be out of calibration, or the actuator is not moving the blend door. Take the glove box out and watch the actuator to see if the rod connected to the blend door is moving. Here is what you will see looking at it. (less actuator)
New Actuator
Broken Gear in Actuator
Old 02-23-2008, 09:47 AM
rbwservices rbwservices is offline
Banned
When the car is running I can hear something opening and closing.
I assume what I am hearing is the actuator opening and closing.
I do not know why it would be opening and closing???
I hear it opening and closing if the heat or cool is on or off.
Old 02-23-2008, 07:39 PM
HotZ28's Avatar
AF Moderator Elite
If you do not answer our questions, we can not help you! Your system must be in the default mode and evidently, you have a flashing light on the digital display. If so, the system will need recalibration.
Old 02-24-2008, 02:45 PM
dksram
Guest
Posts: n/a
Not to butt in.I have a 97' PA with the same problem.
Can the electronic temperature control cause this symptom?
