Old 01-22-2008, 08:27 AM
302Z28 302Z28 is offline
97 Cav 2.2 stumble - rough idle
I have a '97 2.2 Cav. It has 184K miles, auto trans. The problem is intermittent and the check engine light is not illuminated. The main problem is a stumble off idle when accelerating up to about 1200 RPM. From that point on, it runs great. Also intermittent rough idle.
Various codes have appeared, but been rectified.
Parts changed thus far: injectors, fuel filter, coil packs, throttle position sensor. All have been changed to correct "check engine" light.
I suspected bad gas, but alcohol additive did not help.
Any suggestions would be greatly appreciated.
Thanks,
Old 01-23-2008, 08:53 AM
16th hippy 16th hippy is offline
Re: 97 Cav 2.2 stumble - rough idle
would suggest putting a good scanner on it if possible. look at misfir counters(may misfire without setting codes), and so on to try and narrow it down.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-23-2008, 09:21 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Check for vacuum leaks and with those miles you would really benefit from some auto-rx. My 98 Transport with 172K miles was transformed after using auto-rx. No more rough idle.
www.auto-rx.com
