Old 01-22-2008, 02:02 AM
KrnAznEP KrnAznEP is offline
Clutch Vaccum
I just changed my Master Cylinder, Slave Cylinder, and Clutch line for the clutch and there is pressure in my clutch now. However when i pull the clutch out quickly i hear a air sucking sound coming from the master cylinder area. I did remove the vaccum hose and put it back (the one next to the master cylinder). Was there origianlly a sucking sound or is somthing leaking?
Thanks!
Old 01-22-2008, 03:03 PM
DCIV's Avatar
DCIV DCIV is offline
Re: Clutch Vaccum
you did bleed the clutch right?
Coop
Old 01-22-2008, 03:20 PM
inafogg inafogg is offline
Re: Clutch Vaccum
is there a problem with the clutch or brakes...or is it just the noise you're trying to fix???
Old 01-22-2008, 03:32 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Clutch Vaccum
Those hoses are way easy to crack! double check to see if there cracked I know on my clutch booster I had a small crack on the side of the platic nipple where you connect the hose.. I just took the hose off and blocked it off.. clutch is stiff as shit now.. but I like it and it doesnt wistle under boost anymore!
Jason
Old 01-22-2008, 05:22 PM
Re: Clutch Vaccum
yeah i bled the slave. It has pressure in the clutch. I think it might be the vaccum hose crack.
