Old 01-22-2008, 12:41 AM
vhenem vhenem is offline
91 Astro Blower not working
I have a 1991 astro, the blower motor quit while during our move, I tried to buy a replacement but the only thing available at the parts store (NAPA) has only one power connector on it whereas mine has 2. ( I assume one is power and the other ground )
The funny thing is that if the van is running with the blower turned on and I disconnect either of the wires and then plug them back in again the blower will stay running until we turn the van off. attempting to adjust the speed while driving results in the blower turning off.
any good guesses as to what whould be causing this ? and why would all the replacement motors have only a single wiring connector
thanks in advance
Old 01-22-2008, 07:44 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 91 Astro Blower not working
That model year uses a single terminal hot wire-- you must transfer the grounding terminal from the old motor- you'll see how it works when you take the old one apart- In later model years they went to the sealed locking connector types- to eliminate corrosion problems.
Your motor fails in that respect-- Heck- I have seen folks drive them for over a year by kicking (with their foot) the blower motor on. - of course you just need to slam the hood in your case. The brushes are worn- it will only run if you knock the armature off center enough for it to spin on center. The motor needs replaced.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
