Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-21-2008, 10:25 PM
nawlinsmom nawlinsmom is offline
Exclamation 1995 4runner making noise when cold and turning
My 1995 2WD 4runner has a rather loud rubbing/friction sound and vibration through the steering wheel on cold mornings when I make a turn. It started this year when the weather first started turning cool (in New Orleans), and isn't there on warmer days. It goes away after a few minutes once the vehicle warms up, but seems to stick around longer on very cold days. Any ideas?
Old 01-22-2008, 03:05 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1995 4runner making noise when cold and turning
Welcome to the AF!
My first thought is that you may need to flush your power steering system. You may have contaminated PS fluid.
Here is an example of how to do it:
http://www.toyotanation.com/forum/t19334.html
Although the 4Runner is set up differently, the procedure is similar. I just used a hand pump attached to an electric drill to empty the lines and PS pump reservoir.
All the above is probably wrong if you are getting the noise when going around a corner and no noise when you are turning the steering wheel. When you are able to turn the steering wheel silently and the truck makes noise while driving around the turn, then you are looking at a problem in the drive train.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-22-2008, 09:28 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Does it happen only when turning one direction?
Does it happen only when at full lock in one or both directions?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
