Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-21-2008, 05:36 PM
amanda_0_3 amanda_0_3 is offline
clutch noise
i just bought an '04 wrangler. when i have the shifter in the neutral position, and the clutch is engaged it makes an almost grinding noise. when i push it in it stops. i work at a jeep dealership and a tech told me the noise was the input and output shaft and it is just normal unloaded gear noise. does that make sense or is there an actual problem with the clutch or transmission?
Old 01-27-2008, 08:54 PM
acoop822 acoop822 is offline
Re: clutch noise
Hello, I have a 05 Liberty and an 05 Wrangler both manuals and Both make the same noise. My Wrangler is worse, I greased the throw out bearing on the liberty and it Quieted it down...Everything works as normal.
Old 01-28-2008, 06:49 AM
2000izusu 2000izusu is offline
Re: clutch noise
it is a well known noise. it is the reverse idler gear in the nv-3550 (3500?). since this transmission came from 1/2 and 3/4 ton trucks it is considered a truck transmission. and a "normal" noise that will have no adverse effects! mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 01-28-2008, 06:54 AM
Re: clutch noise
since the nv-3550 came in the liberty to, here is a guy with the same symptoms. it is 2 pages long and according to the post jp magazine called the nv-3550 tough but noisey!
link:
http://www.jeepforum.com/forum/showt...hlight=nv-3550
2000 rodeo SOLD
