Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 01-21-2008, 05:05 PM
epmd106 epmd106 is offline
Question 1999 kia sportage will not start
HAving problems with my kia,will not start, seems like it is'nt getting any fire.
HAd battery charged, when I turn the switch it doesn't do anything. I think it may be the starter, and if it is the starter, where is it located on a 1999 Kia Sportage, PLEASE HELP!!!! give me some info.......
Old 01-21-2008, 05:20 PM
D'Expert D'Expert is offline
Re: 1999 kia sportage will not start
Check the negative or ground wire in your battery and try to tightened it.
Old 01-21-2008, 05:24 PM
i did that all the thing in the car comes on like the light and all that but the engine will not turn.......
Old 01-21-2008, 05:30 PM
Check fuse of the starter, if its good, then your starter needs to be replaced or rebuild...
Old 01-21-2008, 07:18 PM
LMP's Avatar
LMP LMP is offline
INdeed it can be the starter itself but historically, Sportage starter failure is rare . YOu must first establish if 12v reaches the starter solenoid coil: there are several places where the circuit can be cut: transmission/clutch switch is one. 40A/80A fuse (circuit varies with year). Failed ignition switch is another. By the way, is it a manual or an automatic ?
DO you hear the starter solenoid "click" ?
TUrn headlights ON: At the moment you turn the ignition key to START, will the headlight fade OFF? (this to test battery connections: bad connecetion can keep lights and instruments ON but when trying to start they all go off)
www.geocities.com/lmp4203/kiasport/FusesOUT.jpg 2000
http://www.geocities.com/lmp4203/kia...ingcircuit.gif 1999
www.avigex.ca/kia/startingsystem.gif 2000
www.avigex.ca/kia/starterrepair.pdf (Starter is on right side of engine, below battery )
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
