Old 01-21-2008, 04:40 PM
DonCapx DonCapx is offline
It just died!
My 96 Park Ave with the super charger died at a stoplight today and refusd to restart.
I get lots of juice from the battery, and it turns over just fine, but will not start.
I have heard you all talk about getting "codes" flashing on the dash, but I can't understand what to look for. Can some advice in this area?
Old 01-21-2008, 04:46 PM
Re: It just died!
Could it be a problem with the ignition module? If so, what are the symptoms, and how involved is the replacement?
Old 01-21-2008, 05:10 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: It just died!
Check for spark & fuel first! This could also be the crank sensor (CKPS)
Old 01-21-2008, 05:33 PM
Re: It just died!
Are the cam sensor and the crank sensor the same thing?
Old 01-21-2008, 05:41 PM
HotZ28's Avatar
AF Moderator Elite
Re: It just died!
No, they are two separate sensors. The crank sensor is located behind (right side) of the harmonic balancer. The cam sensor is located in the center/left of the timing chain cover. BTW, this engine will start & run with a bad cam sensor!
Pic below, shows sensor locations: This is for the S/C engine, however the cam and crank sensors are in the same location on the N/A engine.
Old 01-21-2008, 05:46 PM
Mickey#1 Mickey#1 is offline
Re: It just died!
You have a cam & crank sensor. Cam sensor shouldn't prevent starting but a bad crank sensor will. For 'no-starts' I always recommend checking three things.
1 - spark at each of the three front cylinders
2 - fuel pressure at the rail
3 - fuel injector pulse
Old 01-21-2008, 05:56 PM
Re: It just died!
Thanks for all the adivice. I have a Haynes Manual for the vehicle, but it just doesn't seem to have the info I need.
So I will locate the Harmonic Balancer to find the Crank Sensor. Can this sensor be tested, or should I just plan on replacing it? Do you recommend any special tools or tips?
As a side note, I noticed a strange loud rumbling sound coming from the rear right side (under the trunk area) after attempting a start. Is it possible that I have a faulty Fuel Pump? Would it just stop and never restart if the pump went bad?
I also had a local quick lube shop perform an oil change for me last weekend. The weather in Seattle sucks this time of year and I couldn't bring myself to lay in the rain to do an oil change.
Is it possible that they may have accidentally damaged this sensor?
Old 01-21-2008, 06:19 PM
Re: It just died!
Before changing any parts you need to narrow this down to a spark or fuel problem.
Old 01-21-2008, 06:21 PM
HotZ28's Avatar
AF Moderator Elite
Re: It just died!
The answer to your first question is yes! Check fuel pressure.
The answer to your second question is; possible, but not likely!
Old 01-22-2008, 07:59 AM
Re: It just died!
Thanks all. I'll let yo know how this turns out.
