Old 01-21-2008, 09:20 AM
brentb08 brentb08 is offline
Low Beam Headlights Problem
Low beams are not working, neither one of them. The high beams work. This just appeared to happen overnight. Do I just need to replace both low beam bulbs or could it be a bigger problem since both the right and left side quit working at the same time.
Old 01-21-2008, 09:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Low Beam Headlights Problem
Year make and model?
Pull the bulb and with a old 12 volt bulb type test light or volt/ohm meter see if it is getting good voltage on low beam side.
Some are fused depending on year.
Also it is normal for the left and right side to go within a hr of each other.
Just like they have a built in timer.
MT
MT
Old 01-21-2008, 09:49 AM
02 chevy blazer 4wd
i was also told it could be a relay as well? if it is a relay, i have a 1996 GMC Jimmy 4wd sitting in my driveway and i was wondering if the relays for the blazer and the jimmy are the same and can be swapped out?
Old 01-21-2008, 10:21 AM
MT-2500's Avatar
AF - Advisor
Read post 2.
You need to check things out before throwing parts at it.
Check for voltage aT BULB.
mt
MT
Old 01-21-2008, 11:10 AM
MT-2500's Avatar
AF - Advisor
02 Has two head light setups with ZR2 or without ZR2.
Looking at the wiring diagrams it looks like the headlights are turned on with a ground setup.
Check fuses and for power to bulbs.
Power feed low beam should be yellow and black wire for left and dark blue for right low beam.
The yellow for right and left low beam should be a ground circuit wire from multi function switch to low beam bulbs to turn on bulb.
MT
MT
