Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-20-2008, 11:13 PM
1Bradymichael 1Bradymichael is offline
95 CV runs too cool
Are these cars known for poor heaters in the winter months? I have done everything I can think of. Replaced the thermostat with factory OEM, new radiator(it was leaking),flushed system according to the manual so no air is trapped. I have the radiator blocked, and it still runs below half on the temp gauge. It will climb up to halfway when I start it cold, and then when she is warmed up it will stay at about 1/4 from the bottom and blows lukewarm air.
I am stumped
I am wondering if the new stat from the dealer is bad?
Old 01-21-2008, 04:57 PM
Stick462 Stick462 is offline
Re: 95 CV runs too cool
Have you warmed it up and put your hand on the heater hoses to see if they are hot??.If they are both not hot you have a air lock .To remove the air lock take the top heater hose off the core side when engine is off. Pore anti freeze in till it starts to run out of the heater core /then put hose back on .Check your rad cap.have it checked for pressure.
Old 01-21-2008, 09:12 PM
Been there, done that. New rad. cap as well. I give up on this POS.
Old 01-22-2008, 03:27 AM
reekor reekor is offline
might be due for a new fan clutch.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-22-2008, 06:58 AM
Your thinking is that the clutch is engaged too much?
Is there a way to test them?
Old 01-22-2008, 05:09 PM
Ford have had bad thermstasts or it could have been dropped. I would recheck it first. Could be stuck open.Take it out see.That car should just about cook you out of it.
Old 01-22-2008, 08:37 PM
Yup, To check it start the car cold let it run for two minutes and take a look at the fan, it should be spinning at a slower speed then the water pump pully.
