Old 01-20-2008, 08:14 PM
blazinman08 blazinman08 is offline
front shocks
i have an 89 s10 blazer 4wd 4.3l i am pretty sure i only have shocks up fornt no springs is this right
Old 01-20-2008, 08:23 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: front shocks
yes no springs, but torsion bars, along withthe shocks.
Old 01-20-2008, 08:27 PM
Re: front shocks
so alright now how can i lift the front end just buy new shocks or
Old 01-20-2008, 08:32 PM
2percent 2percent is offline
Re: front shocks
check here
http://www.rockymountainsusp.com/GM_S10_4wd.htm
Old 01-20-2008, 09:24 PM
old_master's Avatar
Advisor/Moderator
Re: front shocks
2WD has coil springs, 4WD has torsion bars on the front, they both have leaf springs on the rear. Springs/torsion bars control ride height. Shocks only dampen the action of the springs, they do nothing for ride height.
Old 01-20-2008, 09:44 PM
Re: front shocks
so how do you lift them the cheap way
Old 01-20-2008, 09:50 PM
old_master's Avatar
Advisor/Moderator
Re: front shocks
There are two ways to do it. The cheap way and the right way. The cheap way isn't right, and the right way isn't cheap. Adjusting torsion bars is NOT the way to do it. The web site mentioned in an earlier post would be an option.
Old 01-20-2008, 09:52 PM
Re: front shocks
this truck has nothign right on it so how do you adjust the torsion bars
Old 01-20-2008, 09:58 PM
Re: front shocks
wont this cause uneven wear on tires and mess alot of stuff up?
Old 01-20-2008, 10:00 PM
old_master's Avatar
Advisor/Moderator
Re: front shocks
4WD front ride height is the vertical distance between the lowest inboard edge of the steering knuckle, (close to the ball joint), to the centerline of the lower control arm pivot bolt.
Old 01-20-2008, 10:03 PM
old_master's Avatar
Advisor/Moderator
Re: front shocks
Absolutely it will! Ride height, if incorrect, will cause excessive, rapid wear of many front suspension and steering linkage parts, and of course, tire wear. Ride height must be checked, and adjusted if necessary, before each wheel alignment. If your alignment shop isn't doing it, he's not doing you any favors!
