Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 01-20-2008, 11:58 AM
EclipseG13 EclipseG13 is offline
Only Getting 6 Volts, Need 12
Well the guy who had my eclipse before me had an amp and sub kit installed so all I had to do was throw my equipment in.
The only problem is its not getting enough juice. Theres a Stero Shop like 2 miles down the road from me and they were kind enough to just hit it with a multimeter. We quickly found that it was only getting 6 volts to the +12 on the amp. Everything (includeing the remote signal) was good.
So we figuered it was a fuse. Today I traced the line (PAIN right in the ass... only 15 degrees out right now) and I have found a little fuse box in the line that has enough room for two fuses.
Now, how do I know what fuses to buy? There are no markings on the box ANYWHERE. My guess was to get a 20 amp fuse but there is two slots. Do I get two 20 amp fuses or two 10 amp fuses?
Any help would be great.
Thanks.
Old 01-20-2008, 12:19 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Only Getting 6 Volts, Need 12
Must be a really small power cable, what gauge is it? 2 20 amp fuses wont be enough. What amp do you have?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 01-20-2008, 12:25 PM
I have a xm-2002GTR
I dont really know what to buy but from what I know most people say 20 amp fuse.
Old 01-20-2008, 12:31 PM
Oh ok, that amp might...put out 200 watts. But anyways, You are talking about the fuse that goes in the power cable coming from the battery right? If so, a 20 amp fuse is waaay too small. And again, what size wire is it?
Caleb
vanilla gorilla
Old 01-20-2008, 12:41 PM
Yes the fuse box is right after the battery, as for the size of the wire. Its pretty fat. My guess is going to be standard guage for running equipment. I cant tell what anything is... its not marked and the guy I bought it from does not remember. sorry i cant be any more help on that lol.
Old 01-20-2008, 01:00 PM
Here is a crappy cell phone pic I snapped of the fuse holder:
Old 01-20-2008, 02:39 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Looks like 10 or 8 guage. Looking at the specs you should be ok with 30's.
Or you may want to get a new amp kit designed to pump power to a 1000w amp and has either a stationary fuse block or a in line tube fuse.
2004 Mazda 6i
1997 Tahoe
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Looks like an 8 gauge, maybe even 10. I would go with it being a 10 gauge. That fuse box only holds one fuse, its way too small to handle the job. What do you think nilla, an 80A fuse?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 01-20-2008, 03:28 PM
So I should get an 80A ?
Old 01-20-2008, 04:14 PM
MazdaX's Avatar
80 may be a bit too much for a amp..if you get a surge and the onboard electronics are not designed to handle 80 amps you'll fry your amp. Besides the factory alternator is only like 70 amps.
2004 Mazda 6i
1997 Tahoe
Old 01-20-2008, 05:22 PM
well i took a 20 amp fuse from the AC slot and put it in and nothing happened... My guess is it still needs more juice for the amp right?
The site says:
Current Drain at rated output (A): 48
Does that mean I should look for something like 60A? I looked around and most amp wireing kits for over 1000W use 100A fuses. Should I just grab one of those?
Old 01-20-2008, 08:25 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Get a whole new wiring kit. Go with a 4 awg wire, and a 60a fuse, you should be fine.
Something like this. It comes with a 100a fuse, but I would buy a 60a and use that instead.
http://cgi.ebay.com/KICKER-PKD4-CAR-...QQcmdZViewItem
95 Talon TSI AWD
97 Eclipse GST
Old 01-21-2008, 01:48 AM
I would throw that poo poo mess thats in that car in the trash and get a new power wire kit. Get 4 gauge since thats what that amp is desinged for. As for the fuse size is doesnt matter too much, as long as it isnt some little poo poo. Just get a good power wire kit that comes with the wire, fuse box, and fuse.
Caleb
vanilla gorilla
Old 01-21-2008, 06:48 AM
JoeShmoe's Avatar
LOL, man i should have looked at the amp first before babbling on. Ai agree with the previous posts, go with a 4gauge wire kit. A 60a should be more than enough for you. I only mentioned the 80A cause I kept frying the 60s in my other car.
Old 01-21-2008, 12:19 PM
Well thats actually what I ended up dooing. I went back and figuered I might as well just buy a new block.
Well, after installing it I am still not getting the amp to turn on.... Really sux.
I guess ill just saying fu©k it untill its a bit warmer out.
