Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-19-2008, 03:16 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
pro 5.0 shifter noises???
ok so i bought a new pro 5.0 shifter for my 2000 trans am ws6, 6 speed..let me start by saying its a great shifter..2nd to 3rd is a breeze now..but there are some minor noises coming out of the shifter area now, that werent there before..first there is some rattling, everything is tight..i triple checked all the bolts..there also is a very very minor whistle..which i think is from not a great seal from the shifter to the car, and its tranny noise coming out....the whistling is not really an issue..but the rattling is kinda always there but you cant really hear it till you get on it, basically it doesnt matter what gear your in either..i checked to see if it was hitting the stops from the pro 5.0 but it appeared to be fine..any ideas or suggestions???? would be much appreciated before i rip the center councel apart again..thanks
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 01-20-2008, 11:05 AM
Re: pro 5.0 shifter noises???
ok so today i took it all back apart and made a rubber gasket to put inbetween the 5.0 shifter and the tranny..it did cut out like 75% of the noise that was there..but there still is some noise..is there like a brake in period for these shifters? or anyone have any ideas?
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 01-23-2008, 07:56 PM
well i figured out that the pro 5.0 are natorious for the "buzzing" noise and minor rattling especially at high rpms..i dont think i can stand it for my everyday driver car..anyone heard anything about the b&m ones..are they any better? theres the link of the b&m one..
http://cgi.ebay.com/ebaymotors/ws/eB...199657283&rd=1
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 01-24-2008, 08:46 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Can you identify the source of the niose? If so, 'think outside of the box', there's always a solution.
Old 01-30-2008, 05:10 PM
FTA9597 FTA9597 is offline
Send a message via AIM to FTA9597
Clutch in not moving engine running still make noise?
Just make more rubber vibration dampeners for various areas.
Even after I did that to my tr56 it still whines a little audibly, but thats just high speed gear wine.
If you find theres no problems on the horizon, just turn the radio up a little.
