Brake Question
I have a '99 GP GT, 3.8L engine. When I have to make a hard stop, the car pulls hard to the right. I've had the brakes checked twice (two different mechanics), and both times I've been told that the brakes look okay. I found out today that I have a bent right rear spindle rod, but I don't know if that would have anything to do with the problem. Is it possible that there could be an issue with the anti-lock system?
Thanks! |
Re: Brake Question
with respect to all mechanics, A hard pull to the right would indicate to me that the left caliper is not functioning properly or the slider assy. for the left side is frozen.
There could be a number of issues that cause this problem. Low tire pressure, colapsed hose, ABS, perportioning block, master cylinder ect. I would want to know first off that the calipers are working properly, sliders and all. A frozen caliper would be like the breaks not working on that side. |
Re: Brake Question
believe it or not, my car dynamited hard to the left every time I hit the brakes unless I was holding the wheel straight. My lower controll arem bushings were bad. Have a mechanic check those out. Once I replaced mine, all was fine!
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: Brake Question
2004 GRAND PRIX GTP COMP G. VIN 4 : OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST. 2004 Honda Odyssey EX-L
Re: Brake Question
Collapsed hoses have often been the culprit on other cars that pull hard to a side. A Seized caliper or sliders would also have the same effect. A faulty ABS unit can also cause/have problems dividing the hydraulics evenly (But you'll usually get an ABS light if the unit is misbehaving)
Re: Brake Question
Thanks, everyone for your replies. Looking into the suggestions.
Re: Brake Question
Just wanted to provide some feedback on this post. I did have the bent rear spindle rod replaced. It's either a coincidence or the problem with the hard right pull during braking is gone. I've run about 200 miles since the repair, and tried several "panic" stops. Apparently this mechanic knew what he was talking about!
Re: Brake Question
The bent rod was causing an alignment issue, and when you hit the brakes, it caused that wheel to "steer" to the right. Same with tblakes problem, different part bad, but same result.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
