Old 01-19-2008, 12:17 PM
Jim Y Jim Y is offline
1990 Accord - Cranks but wont start
Have 1990 Accord. Cranks fine but will not start. Tried jump starting with no success. Started problem with cold weather. Any clues?
Old 01-19-2008, 12:24 PM
somick's Avatar
somick somick is offline
Re: 1990 Accord - Cranks but wont start
Regular maintenace? Spark plugs, wires, distributor cap?
How about fuel filter?
Do you have spark?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 01-19-2008, 12:31 PM
No have't tried anything yet. I don't know much about cars so was trying to figure out where to start.
Old 01-19-2008, 04:42 PM
somick's Avatar
That is where you start: new spark plugs, new distributor cap and rotor. Probably new wires.
Good luck,
Sam
Old 01-19-2008, 11:25 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Old 01-20-2008, 12:46 AM
mpumas mpumas is offline
All the things suggested are the cheapest places (about $75.) to start and if they are old probably would not hurt in the process in trying to get it running. However, my method would be to determine if there is spark and fuel first, then go from there. Don't throw money at the car unless you have reasonable belief that it is in the right direction.
Old 01-20-2008, 08:27 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Take the distributor cap off and see of the rotor turns when you crank the motor...if not the timing belt broke or the lower bearing in the distributor seized and sheared...
If it turns, pull one spark plug wire off a plug and put a spare plug into it, and set the business end of that plug on a grounded part of the motor (not the valve cover) and crank the motor, you want to see a nice hot white/blue spark in the plug gap.
If you have a good spark, try shooting some starting fluid into the intake. If it fires up on that and dies, the problem is fuel related.
This will at least narrow it down and we can go from there...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 01-20-2008, 09:46 PM
ProMan ProMan is offline
That's what I would do. I won't throw money on parts blindly, no matter how cheap they are (I am cheaper.....).
The first thing I would do is check if you got spark. That's where you start. Let us know how you doing.
Old 01-26-2008, 12:13 PM
OK - Here's the story. I followed you advice and results are:
Rotor Turns - Good news I guess.
I replaced plugs and distributor.
Tested for spark - No spark. Does not appear to be firing.
Next steps - Should I replace wires ($25) or Ignitor ($65)? I have no idea how to locate the ignitor but autozone guy recommended these two items.
Thanks for the help.
Old 01-27-2008, 12:53 AM
wiseguy01's Avatar
its gonna be your icm aka ignition control module or your cps to eliminate the icm take off distributor and take it to autozone have them test the icm its mounted internally inside the distributor and if its bad then replace distributor if not then your prob is crank position sensor but i really think its the icm i had the same problem
p.s the icm is hard as hell to replace and also i think your cps is in there too and about four other boxes also you get a lifetime warranty with the rebuilt distributor
Old 01-27-2008, 01:24 AM
He sez he repaced the distributor so he has a new ICM (Igniter), coil, crank position sensor +2.
Old 01-27-2008, 03:33 AM
wiseguy01's Avatar
then why does he ask to replace the ignitor then theres only one and its the icm
also the only known place for cps is in distributor
Old 01-27-2008, 06:56 AM
See if it will run if you let the key drop back just enough from the start position that the starter stops cranking, but not all the way back to the run position...my friend's '89 developed a bad contact in the run position the other day out of the blue and wouldn't start...
I noticed that with it in run position, the accessories were on, but no display of dummy lights on the dash or clicks indicating main relay or fuel pump coming on, but if I rotated the key slightly forward or back from it's resting position it would come to life...and it would run if held there after cranking.
His would make an attempt to run each time you cranked it though, if yours is completely dead and doesn't fire at all this may not be the problem...
But see if you have idiot lights and hear relays energize with the key in the run position, if not you may have a similar issue...
...empty gun rack.
Old 01-27-2008, 01:42 PM
wiseguy01's Avatar
i see i had that kind of prob with my ignition switch the car would stay on if held in the start position as soon as you let go it shuts off of course as you would know that would mean i would have to grind the starter lesson learned
Old 01-29-2008, 12:49 AM
Keep us advised on what you find.
