Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-18-2008, 08:29 PM
camaromanalways camaromanalways is offline
Angry 94 Z28 issues...
alrighty...
my camaro is a great running car, purrs like one angry kitty... but i have one issue which is making my life difficult...
when i started up the maro.. obviously it was cold.. and my oil pressure gauge was right in the middle at idle... no problems so far... because my camaro had a dead battery i was giving it some gas, then letting it idle for a bit and just doing an overall check...
the car was running for about a half hour and after a few revvs, the oil pressure gauge was hovering just above the 0 at idle, and when i gave it some gas it would go up one notch and then when i let off, it would go right back to just above 0
now.. as i'm in the car revving it through this time.. i see the needle slowly go lower and lower with every rev
the only thing i can think of (with limited knowledge) is an oil pump going bad or a head gasket.... again.. that is with very limited knowledge
any help would be greatly appreciated
thanks,
TJ
Old 01-19-2008, 12:52 PM
gorgepr gorgepr is offline
Re: 94 Z28 issues...
Originally Posted by camaromanalways
alrighty...
thanks,
TJ
I'll go with a bad oil pump first plus its a 13 year old car a new pump can help him a lot plus its cheap I bougt one in a local autoparts and it cost 30 something dolars
Old 01-19-2008, 01:00 PM
thanks, i have to wait until about may before work can start (semester at college) so i'm trying to figure out the problem now, so I can get it taken care of for summer
Old 01-19-2008, 01:04 PM
the oil pump its really easy to change it took me a few hours to do it you just have to raise the engine a few inches and remove the cran cover and there you find the pump
Old 01-19-2008, 01:12 PM
it's good to know that it can be done on a lazy sunday afternoon...
i went out today and i had the same issue with the car... when it warmed up (a half hour later) the oil pressure hovered just above the 0 at idle and went up when revved to about the first notch, then goes right back down to just above the 0.... now... i also noticed that the heat gauge was slowly inching it's way up into the danger zone
Old 01-19-2008, 01:28 PM
easy first check the oil cap on the valve cover, if it looks like cofee color you problaly have mixed oil and water, that a f...... up engine, but dont go so far when the car its cold remove the radiator cap and star the engine if the water goes out of the radiator you should have a bad head gasket and if you say that the temperature goes up the gasket sould be the problem, I'll sugest you to stop using the car until you found out what is it cuz if keep overheading it or running it with out the sugestet oil pressure you could lose your engine and it will not be cheap to rebuild it
Old 01-19-2008, 01:47 PM
well.. i can't drive it around anyways because i dont get my license back until april, so driving it is no issue, and i'm gunna go look and try those both and see where it stands
Old 01-19-2008, 02:01 PM
ok.. i checked the oil cap.. and it's perfect... still looks almost new (and i know for a fact it's never been replaced) so no water in with the oil...
now.. the radiator cap doesn't want to come off, so i tried pullin off the cap to where you add coolant and there was nothing there... do i need to pull off the cap right on the radiator? because that rat bastard did NOT want to come off...
Old 01-19-2008, 02:14 PM
when i say there's nothing there, i mean nothing came shooting out
Old 01-19-2008, 02:34 PM
thats right you have to take the cap out, with the car cold force the cap down, and twist it to the left, it has to come out but dont do it if the engine has been running
Old 01-19-2008, 02:43 PM
alrighty.. i'm gunna go do that right now
Old 01-19-2008, 02:49 PM
nope.. nothing came shooting out... thing was full of radiator fluid too... so that's a good thing.. lol
Old 01-19-2008, 02:52 PM
also the radiator fluid looked great... no oil in it ( i was told to look for oil in the radiator fluid also by a buddy.. just to make sure)
Old 01-19-2008, 02:54 PM
nothing else comes to my mind man ill do some more research and ill let u know good luck
Old 01-19-2008, 03:02 PM
hey man, i greatly appreciate the help... i got time on my side, so that's a good thing.. lol
and just to be sure.. we have narrowed it down to the oil pump.. right?
