Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-20-2003, 09:56 PM
TMUMMY TMUMMY is offline
Best engine for all-motor?????
What is the best honda engine to use an all-motor setup????
PLEASE REPLY!!!!
Old 02-20-2003, 10:00 PM
VR6Turbo VR6Turbo is offline
I think I would go with an H22. Larger displacement, easier to get more power because you arent using turbo or anything.
(Just my opinion)
Old 02-20-2003, 11:23 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
the new K20 heck the k20 in the rsx type r is suposed to have like 220 hp
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 02-21-2003, 11:12 AM
Alright the h22a, if put in a del-sol would cause oversteer and all that kind of stuff? And would it fit in a del-sol?
Old 02-21-2003, 12:36 PM
Neutrino's Avatar
Yaya Master
ask hybridsol he should know.
(\__/)
Old 02-21-2003, 06:20 PM
yea, i didnt think of the k20. I are they supposed to be bringing the RSX-R to the US? That would be awesome. I just figured the h22 because it has been around for a while, and there are a lot of parts available.
When you put any engine with over 200 hp into a del Sol, you are going to get torque steer, not just with the h22. I really dont think you have to worry about oversteer, (the back of the car whipping out), in a FWDer. I think understeer would be a lot bigger problem.
Old 02-23-2003, 10:41 AM
Would it still get torgue steer if I were to put on a lsd? And what is understeer? Is all of this understeer and torgue steer dangerous?
Old 02-23-2003, 02:17 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
an lsd will either eliminate it or reduce it, depending on how much hp your runnin. torque steer is dangerous cause you dont wanna go flying into the other lane and hit the other car or even wreck yoru car for that matter by going flyin into the wall
Old 02-23-2003, 02:46 PM
Neutrino's Avatar
Yaya Master
Actually some lsd's can make torque steer worse. So i recomend going with a quaife they make the best mechanical lsd's and they should reduce some of the torque steer and at worse not increase it.
(\__/)
Old 02-24-2003, 10:26 AM
So if I am just driving somewhere torgue steer is always going to happen no matter what? and can you get use to it, where you can control it after awhile, or will be a big problem that can never be controled with out a lsd
Old 02-24-2003, 01:51 PM
torque steer only happens under hard acceleration, so if your just daily driving crusin around, you wont have torque steer
Old 02-27-2003, 10:27 PM
Understeer- Have you ever tried to corner in a FWD under hard acceleration? The front tires start to roll over and it is hard to turn. Not really dangerous in normal driving.
Oversteer- Go around a corner in an RX-7 or TransAm and floor it. The ass of the car spins around and you loose control. Very dangerous in normal driving. (If you like to race)
There are ways to modify the suspension in FWD cars to eliminate understeer, but I dont know them, having never road raced a FWD car.
Your main problem with putting a high horsepower engine in a del Sol (with a stock suspension) is the torque steer. The car jumps sideways when you give it throttle. I dont know of any websites that can hook you up with better suspension either. Try to go into the Civic and Integra Forums.
Old 02-27-2003, 10:29 PM
You should ask Hybridsol, with a name like that, it sounds like he may have have put a high-horse engine into a delSol.
Old 02-28-2003, 03:32 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Yes it would fit in a Del-Sol and no the oversteer is really not that bad at all.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 03-10-2003, 09:03 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Yeah it fits in the del sol, but would you really want a 300 lbs weight increase on the front end? Yes, those numbers are real, they are'nt estimates. If you're drag racing, this does'nt matter, but, well... you decide.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
