| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
headlights and parking lights, interior lights wont turn on
ok so i put a front mounted intercooler on my car.. and after taking the fog lights out and hooking up the intercooler and everything back together, i try turning my lights on and nothing happens.. i do notice if i turn the interior light on with the key OFF it will work, but as soon as i turn it on the lights goes out.. do u think taking the fog lights out caused the problem? or a short somewhere or something? please help me out its annoying me so bad.. thank u
Re: headlights and parking lights, interior lights wont turn on
i also forgot to mention that i checked all the fuses and they are good.. i played witht the wires going to the lights and nothing.. but its gutta be something inn the front cause it didnt start doing this until i put the front mount on
2) As soon as you turn the car on the dome lights shut off? 3) What lights did you say at first that didin't work? Just your ints or your headlights too (which you only mentioned in the title?)
'98 Contuor SE, 2.5 V6 Auto Silver '08 Altima 2.5S, Auto Super Black |
yea sorry about the bad explanation.. heres what is hapeneing.. i put a front mount in the car.. after i reinstalled the bumper cover. i hooked the battery back up, the lights worked.. but then acouple days later i went to turn them on and nothing works, dash, parking, headlights everything.. BUT the blinkers, reverse, and brake lights work when pressing the brake of turn signals.. all the fuses are good.. and there is NO power to the dimmer switch, (i read some ppl changed the dimmer swithc and it fixed everything). and there is a thing of wires that comes out of the fuse box under the hood, i tried moving the wires around and all of a sudden the fan turned on.. so i think there might be a bad ground somewhere or something..
Was the car turned on when the fan came on?
the key was on but the car was off. and BOTH fans come on.
Ok, well your blinkers, reverse, brakes, and pigtails i believe are on the tailamp circuit. My guess would be to take a look at (again) the headlight fuse. That would explain the why the other outside lights don't work.
Your cluster lights might be out cause your dimmer switch might have blown. If you are able to jump the wires i would go ahead and do it to rule out the switch. And for the fans coming on, you said the key was in ON position right? Not the ACC position, which would not cut the AC on. Having the the AC left on and turning the key to the ON position will turn on both fans and open the thermostat. NOT to say these are reasons or solutions, just giving you some ideas as to what it might be. Try them out, hopefully you can fix some problems.
alright thanks, i was looking around today and i noticed that my raditor has been leaking and there is absolutly no fluid in it and i noticed a sensor in the botom of the radiator, would that turn the fans on? cause i have the ac off. and i checked out the dimmer switch and there is NO power getting to it.. and double checked the fuses, and they are all good.
Well that's as far as I can go. My 2g radiator does not have any sensors on it. CAn you snap a pic of the sensor? And the dimmer being starved......man i can't think other than tracing back your wires. Have you tried jumping the wires together for the dimmer?
no i havent tried jumping the wires yet.. i just unplugged the dimmer and tested for power with a test light.. but i will try jumping the wires. and i will take some pics of the sensor because i am replacing the radiator today after work.
Rightous bro, that will really help out.
ok so i found a blown fuse.. and now my radio and dome light work.. but i still gutta figure out why my parking lights/headlights, and gauge light wont work.
yea the alternator is good. battery is in good condition. everything is working properly. but i also noticed that my radio does not save the memory.. and it was saving before i did the work on the front mount. but now it isnt. along with the parking lights gauges and headlights.
I'm still convinced its a blown relay. Then again you have 1G, lol. I'm not familiar with the wiring. I'm gonna review your wiring and see what i can come up with. ***EDIT*** Damn it, I could find anything for your car online. Is there someplace you know of online where I can go and check it out.
'98 Contuor SE, 2.5 V6 Auto Silver '08 Altima 2.5S, Auto Super Black Last edited by JoeShmoe; 01-26-2008 at 03:06 PM. |
