Old 01-18-2008, 01:31 PM
BiggWaukegan BiggWaukegan is offline
91 Civic Hatchback...Distributor
Can you guys PLEASE help me out here... Got the replacement dist. for my 91 hatchback 1.5 motor... How do I replace it myself? thanks
Old 01-18-2008, 02:10 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: 91 Civic Hatchback...Distributor
its three bolts and three pluggs just mark the old dist and set the new one to the mark and your done put new cap and rotor though
Old 01-19-2008, 12:57 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Fairly simple: Mark on a piece of paper or somewhere the arrangement of the spark plug wires on the cap(writing on the cap works ). Remove spark plug wires. Disconnect the 2(IIRC) electrical plugs. Remove the 3 12mm bolts holding the distributor to the head. Remove distributor.
Your done. Check your cap and rotor and see what condition they are in before you go and replace them. If they look really corroded or chipped up or anything, go ahead and replace them, if not, leave them alone. It takes a little while for new caps and rotors to break in and until then, your not getting the best gas mileage you can out of them
Tony
91 Civic Sedan DX - Stock 287k Miles
